  1. Banned
    Dec 2003
    I've just installed my new optorite DD1203. I've tried to burn four discs all coasters. I kept my sony 500a installed and tried a burn with it, also a coaster. Nero 6 gave me a power callibration error on every burn. Below is a log of th proccess. Oh, It reads just fine, got up to 11x, just can't right.
    1A23-2031-9054-9207-3925-4451
    Windows XP 5.1
    IA32
    WinAspi: -
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/2003 3:25:04 PM
    Nero version: 6.0.0.11 (Nero Express)
    Recorder: <OPTORITE DVD RW DD1203> Version: 100E - HA 1 TA 0 - 6.0.0.11
    Adapter driver: <atapi> HA 1
    Drive buffer : 2048kB
    Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
    Connected to MMC as unknown drive with class-nr : 1
    Drive is autodetected - recorder class: Std. MMC recorder
    CD-ROM: <OPTORITE DVD RW DD1203 >Version: 100E - HA 1 TA 0 - 6.0.0.11
    === Scsi-Device-Map ===
    DiskPeripheral : ST340016A atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : OPTORITE DVD RW DD1203 atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : SONY DVD RW DRU-500A atapi Port 1 ID 1 DMA: On
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 40894464 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 255MB (261424kB)
    Free physical memory: 126MB (129508kB)
    Memory in use : 50 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    24.6.2004
    ===== Disc-Copy over image - 1st step : Copy to image ...
    7:59:17 PM #1 Text 0 File Reader.cpp, Line 118
    Reader running
    7:59:17 PM #2 Text 0 File Writer.cpp, Line 127
    Writer Image Recorder running
    7:59:19 PM #3 Text 0 File DVDCopy.cpp, Line 173
    Max -1 tracks of 1 allowed to copy
    1: 0 - 865264 = 865264, TRM_DATA_MODE1, block size 2048, read opt 0 (no read options)
    7:59:19 PM #4 Text 0 File Burncd.cpp, Line 3173
    Turn on Disc-at-once, using DVD media
    7:59:19 PM #5 Text 0 File DlgWaitCD.cpp, Line 228
    Last possible write address on media: 2147483646 (477218:35.21)
    Last address to be written: 865263 (192:16.63)
    7:59:19 PM #6 Text 0 File DlgWaitCD.cpp, Line 233
    Write in overburning mode: FALSE
    7:59:19 PM #7 Text 0 File DlgWaitCD.cpp, Line 1722
    Recorder: Image Recorder;
    CD type reading failed
    ATIP Data: ?
    7:59:19 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 768
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (1 Data (mode 1))
    2 indices, index0 (150) not provided
    original disc pos #0 + 865264 (865264) = #865264/192:16.64
    not relocatable, disc pos for caching/writing not required/not required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 865264 blocks [ Image Recorder ]
    7:59:19 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 937
    Prepare recorder [ Image Recorder ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 1772367872, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    -150 | lead-in | 0 | 0x00 | 0x41
    -150 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    865264 | lead-out | 1 | 0x00 | 0x41
    7:59:19 PM #10 Phase 120 File dlgbrnst.cpp, Line 1843
    Creating the image for burning
    7:59:19 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 2130
    Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
    8:02:39 PM #12 Text 0 File WriterStatus.cpp, Line 113
    < Image Recorder > start writing Lead-Out at LBA 865264 (D33F0h), lenght 0 blocks
    8:02:39 PM #13 Text 0 File ThreadedTransfer.cpp, Line 227
    all writers idle, stopping conversion
    8:02:40 PM #14 Phase 121 File dlgbrnst.cpp, Line 1843
    Creating Image completed successfully
    ===== Disc-Copy over image - 2nd step : Burn the image ...
    8:02:54 PM #1 Text 0 File Reader.cpp, Line 118
    Reader running
    8:02:54 PM #2 Text 0 File Writer.cpp, Line 127
    Writer OPTORITE DVD RW DD1203 running
    8:02:54 PM #3 IMAGEGEN -10 File ImageGen.cpp, Line 363
    Image was written as DAO.
    DAOI:
    MediaCatalogNumber = ''
    TocType = 0x00
    Finalized = 1
    First/Last Track = 1 / 1
    1: ISRC = ''
    Blocksize = 2048
    TrackMode = 'TRM_DATA_MODE1'
    TrackConfig = 0x00
    First/Last Index = 0 / 1
    Index0FilePos = 0, Index1FilePos = 307200, NextTrackFilePos = 1772367872
    CUES:
    0: Ctrl=0x41 Trk= 0 (0x00) Index=00 RecDep=0x00 Start=954437:08.46 ( -150)
    1: Ctrl=0x41 Trk= 1 (0x01) Index=00 RecDep=0x00 Start=954437:08.46 ( -150)
    2: Ctrl=0x41 Trk= 1 (0x01) Index=01 RecDep=0x00 Start=00:00.00 ( 0)
    3: Ctrl=0x41 Trk=110 (0xAA) Index=01 RecDep=0x00 Start=192:16.64 ( 865264)
    MTYP: Mediumtype = DVD (old format) (0x1C)
    8:02:54 PM #4 Text 0 File Burncd.cpp, Line 3173
    8:03:21 PM #5 Text 0 File DlgWaitCD.cpp, Line 228
    Last possible write address on media: 2297887 (510:38.37)
    8:03:21 PM #6 Text 0 File DlgWaitCD.cpp, Line 233
    8:03:21 PM #7 Text 0 File DlgWaitCD.cpp, Line 1722
    Recorder: OPTORITE DVD RW DD1203, Media type: DVD-R
    Disc Manufacturer: RITEKG - 05
    Disc Application Code: 64, Disc Physical Code: 193
    8:03:21 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 768
    0: TRM_DATA_MODE1 (DVD-ROM)
    2 indices, index0 (150) provided
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 865264 blocks [OPTORITE DVD RW DD1203 ]
    8:03:21 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 937
    Prepare recorder [OPTORITE DVD RW DD1203 ] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    Tracks 1 to 1:
    DAO layout:
    8:03:21 PM #10 Phase 36 File dlgbrnst.cpp, Line 1843
    Burn process started at 4x (5,520 KB/s)
    8:03:21 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 2130
    8:03:21 PM #12 Text 0 File dlgbrnst.cpp, Line 1703
    Set remaining time: 5:37,332 (337332ms) -> OK
    8:03:21 PM #13 Text 0 File DVDR.cpp, Line 1485
    Recording mode: Sequential Recording Mode
    8:03:21 PM #14 Text 0 File Mmc.cpp, Line 18878
    Set BUFE: ExacLink -> ON
    8:03:21 PM #15 Text 0 File DVDR.cpp, Line 1600
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    8:03:21 PM #16 Text 0 File Cdrdrv.cpp, Line 7906
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26127F h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    Media Specific:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    8:04:24 PM #17 SCSI -1106 File Cdrdrv.cpp, Line 1415
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x058F0000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x73
    Sense Qual: 0x03
    CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
    0x00 0x00 0x00 0x00 0x73 0x03
    8:04:24 PM #18 CDR -1106 File Writer.cpp, Line 335
    Power calibration error
    8:04:24 PM #19 Text 0 File ThreadedTransfer.cpp, Line 227
    8:04:25 PM #20 Text 0 File ThreadedTransfer.cpp, Line 221
    conversion idle, stopping reader
    8:04:25 PM #21 Text 0 File dlgbrnst.cpp, Line 1703
    Set remaining time: 0:00,000 (0ms) -> OK
    8:04:25 PM #22 Text 0 File dlgbrnst.cpp, Line 1703
    8:04:25 PM #23 Phase 38 File dlgbrnst.cpp, Line 1843
    Burn process failed at 4x (5,520 KB/s)
    Existing drivers:
    File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 7/16/2003 3:24:25 PM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. Hi james636.
    I'd suggest you update to the latest version of Nero, as some of the earlier v6.x releases were quite buggy.
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
