what program do u use to convert divx movies to mpeg movies
someone plez help me
<font size=-1>[ This Message was edited by: duncan21 on 2001-07-13 07:46:47 ]</font>
the file name is : 10 things i hate about u (divx).avi
i need to make that toa mpeg -
did u try this link as well?
http://www.vcdhelp.com/tmpgenc.htm
Are you going to mpg or vcd-ready mpg?
I use virtual dub to uncompress the audio to 'uncompressed audio' (workz better or less glitchier than straight divx audio, mp3 or wma2 audio), pushes the file size to around a gig or so, then load up avi2mpg or tmpgenc 12 or 12a and encode to vcd. You may want to cut your divx into two parts first then encode; it;ll be easier to encode to to mpgz then to cut it afterwards, and your filez should be in synch.
go to
http://www.divx-digest.com/articles/index.html, or http://www.doom9.org
read their guides or Nicky'z guides. cue up your filez grab a cold one and encode away.
ZtR -
k, list exactly what stepz you're taking to try to convert it. The pc config you got, what software, which codecz you've installed, and which appz you're using to convert it.?
Itz got to be either audio, codec, or winOS related. But if you list the stepz we may be able to troubleshoot it better.
What kind of divx is it? One that you encoded, tele-sync, screener, smr, cam, what error messages if any are u getting and from what app/step. Is virtual dub (14d had a bug with pc's running norton antivirus so if 14d patch it up), or 14c, parsing the movie properly? have u tried the divxfix.zip file to see it the movie is freezing at any one point?
ZtR
Burned Divx movies stopping before end...
By Jeffross1968 in forum DVD RippingReplies: 9Last Post: 18th Feb 2012, 12:08 -
Cleaning up old home movies on mpeg
By illyad in forum RestorationReplies: 8Last Post: 10th Dec 2007, 07:01 -
How many Divx movies should I put on one DVD+R?
By Hank Kinsley in forum Newbie / General discussionsReplies: 11Last Post: 17th Aug 2007, 04:39 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13 -
Burning Divx movies with subtitles?
By Hank Kinsley in forum SubtitleReplies: 5Last Post: 17th Jul 2007, 12:33
