OK, I am having the hardest time getting this done!
Can someone give me either:
step-by-step instructions
or
recomend a program that is user freindly that will do this for me?
I'm in a situation where this sort of conversion is necessary!
use quicktime pro or squeeze or procoder or vegas or premiere pro ..
load file -- render to quicktime ..
squeeze generally gives the best results ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I have Quicktime Pro. That will convert any of my files into .mov?
How? HOW?!?!?
WAIT! OK, I see that 'import' choice.
ok! i see! i'll try my .avi file...
WAIT!
It says I need some compressor that I don't have? WHAT?
Now what do I do?!?!?
WAIT!
OK! I got it now! It worked with my .mpg file!
Whew! Thanks man!
THANKS!!!!
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
It's no good. It didn't work BJ_M.
I was able to convert my .mpg files (as so I thought) to a .mov using my QuickTime Pro.
I would go to file/import and pick out the .mpg I wanted to convert to .mov and then choose 'convert'. Well, it seemed to go through a quick process. When it was done it would start to play the .mov but it didn't seem to be saved. So, I would 'save' it.
Then I took the necessary ".mov" file and uploaded it to the site I needed it to be viewed at. when I went to click on it 's new link nothing would happen. A window would pop up but act as if frozen.
What am I doing wrong?
the page the dead quicktime .mov's are located at right now is: http://www.waggingtongues.com/Animatehome.htm
I'm going to look into that squeeze program you were talking about. -
Why do you want to convert the files? They are a pain in the ass to convert back to anything else.
This plan is so bad, it must be one of ours. -
My site is always being visited by idiots! Don't you see? MAC users who know diddly squat about video but get demanding and want to see our annimation.
That's why!
I can't get over what an issue MAC has made of itself with this.
I mean, if I put just my .mpg files up instead, would that be sufficiant enough?
If you want a real good laugh, you should see the emails I get from some of these MAC users. -
whats this got to do with mac users?
any may user can view any of those extensions you are talking about.
whats the problem here?!?! i dont see one
whats your site....... i also dont see one.
DV4 to AVI, MOV or WMV
By marhny in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2012, 10:45 -
Is DivX avi is better than flv, wmv, and mov?
By dread in forum Newbie / General discussionsReplies: 12Last Post: 20th Apr 2011, 12:38 -
HD Movie Editing/Authoring - AVI, WMV, MOV, etc.
By jp_drums_4evr in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2008, 13:31 -
Convert .mov to .avi or .wmv?
By cielspacing in forum Video ConversionReplies: 13Last Post: 3rd Apr 2008, 14:11 -
Playback video too bright in mov, mpg, avi, wmv, etc in all players
By PhilippZ in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 16:02
