Hi !
I'm making a dvd-music dvd (only music with some motion menues).
I have a menu for each and every song. Totaly 200 songs in mp3-format.
When I build the project in Adobe Encore a message appear where it says the size of motion menues are to big (something like that) so i can't create the dvd! The size can not be over 1 gb.
I have only one motion menue and thats in the main menu. When I remove that motion menu and build the project, the same message appears.
Does the songs in every menu make the menues to motionmenu or what? I really need help with this.
Results 1 to 10 of 10
If you have audio on each of the 200 (?) menus, then Encore may well be creating a motion menu for each. It is probably also converting the mp3 audio into LPCM which will eat a lot of space as well.
Ok. thanx for your answer.. What transcode is the best for the audiofiles in this project?
In this case, mpeg-1 layer 2 is probably your best bet, but only if you live in PAL land. Otherwise you will need to get an AC-3 encoder.
Or, change the structure of your disk. If you have created all these menus in order to play back the songs, try putting all the songs in a series of clips (say 20 songs to a clip, 10 clips), with chapter stops marking each song. You will get around the size restrictions this way. -
I dont't know much about EncoreDVD only it is a program supporting many options. So there should be a possibility to create a slideshow as menu. So if, try this to shrink your menusize.If you have audio on each of the 200 (?) menus, then Encore may well be creating a motion menu for each
ok thanks again for your answere.. but <cona812>, what do you mean with menu slideshow?
I don't think It's possible in Encore, or it is?
If I get an AC-3 Encoder, will it increase the size of the files? -
I only took a short look at Encore, so I really don't know much about it. I am using scenarist and you have the possibility to use a still as a slideshow there. You can set the duration of the slideshow and you can use an audiostream (not possible with still menus).
Ahh.. i see.. ok! But I have to make this dvd on Encore..
Is there any other way to come around this problem with to big motion menus?
If I could ignore the message and make the dvd anyway, then use dvd shrink maybe.. -
If I use a AC3-encoder, should I first encode my mp3-files outside Encore or does Encore inside the software with transcode?
If so, what kind of transcode should i use to encode with ac3 codec? -
I won't use so many menus. So the first thing i would do is to put four tracks together in one menu, for each menu i would encode an ac3stream (192kbps, 2.0) with a duration of 10 or 15 secondes. The resulting size for all menus would be something around 20MB (by using slideshows) or ~300MB (when using motionmenus with 3000kbps m2v and 192kbps ac3).
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Menu thumbnails are too big
By HMD in forum Authoring (DVD)Replies: 0Last Post: 5th Mar 2010, 06:43 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 16:45 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
GFD motion menu stuttering
By spamiaint in forum Authoring (DVD)Replies: 2Last Post: 15th May 2008, 10:58
