Hi there,
I have the Teac CD-r 58s (SCSI 8x) and I read that in order for the cd-recorder to be able to burn a 90 min cd-r, I should run it in CD-R 55s compatibility mode.
How do I do that ?
Thx in advance.
You have to "close" a jumper (marked as reserved on manual) on the back of the unit. I don't remember which of the two reserved jumpers.
When this jumper is closed, you will see the unit as a Teac 55S, with a maximum speed of 4x.
I found the instruction on http://www.blindwrite.com on the compatibility page.
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
Help make my Teac DV5188 region-free
By cinnie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Sep 2010, 07:44 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
Looking for help with a Teac DV-3120 mkII
By cubepunk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Sep 2007, 00:12 -
Teac DV-H350
By length in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd May 2007, 13:32
