Hi,
I have created several two disk SVCD's using VCDEasy to burn the cue file.
The SVCD's work absolutely fine on my Alba DVD 114 machine however, when I try to play them in my Samsung DVDR-4000 the machine recognises the disk and will play it but both the sound and picture are jittery.
As I am a novice to this sort of thing I don't know whether changing certain settings on the machine will able it to play smoothly or not.
Does anyone know what could be causing the problem and how I can fix it?
Thanks.
Hello,
Does the Samsung specifically say it will play svcds? If not then it will be hard to play them since they are in a sense vcds on stereoids. You could try the vcd header trick listed in the conversion guides on this site. Other than that there might not be too many options since svcds are unique. Best of luck.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Major Video Playing Problems..
By SpazRaven in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2011, 15:43 -
problems playing dvd movies
By bexiga in forum DVD RippingReplies: 2Last Post: 5th Jan 2009, 19:37 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 07:31 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 07:57
