I updated the ASPI layer in my computer to ver. 4,
now DVD Decrypter says No Devices Found.
Can someone explain to me why no devices are found.
Thanks....
Results 1 to 14 of 14
When it sounds too good to be true, it usually is!!
I have Roxio installed on my computer and got the same message originally. IF this is the case...the Roxio site has the fixes.
If you're using Nero you need the Nero ASPI driver. If you're using most anything else you use the Adaptec ASPI.
I had to install the Adaptec ASPI and "DriveUp" (updates the list of drives) with Roxio installed.
All went smooth after that. -
10-X for the replies...
When it sounds too good to be true, it usually is!! -
Update.
ASPI (v4.71.2) was my problem. I kept on digging and found ASPI v. 4.6.
That solved my No Devices Found problem. I used DVD Decrypter without any problems.When it sounds too good to be true, it usually is!! -
ASPI v4.71.2 usually works if you do the "Exclude Miniports" patch. I don't know why Adaptec hasn't fixed it yet, alot of people have the same problem.......the installer doesn't add all the registry entries you need.Originally Posted by Bronx
I know this is an old topic. But i am getting a dvd burner and i use nero on my CDRW which will be replaced with the Pioneer 108.
Do i happen to need ASPI V4.71.2 or is it called Force ASPI?
If i happen to use other dvd burning software will my ASPI drivers still be working even though im not using nero? -
force aspi is more meant for XP.. but if your burner is currently working then you should be fine.. BUT aspi 4.6 is the most stable out there ATM. if you have no problems thens stay where you are.. if you run into some not found errors.. then just get 4.6 i found it on doom9s site.. dvd2svcd has it also.. but google it and youll find a copy.
Thanks I do have XP but i'll stick to what you were saying about 4.6
BTW what version is the aspi that is on the nero ftp site? -
not sure. nero and adaptec have their own.... as they say if it aint broke dont fix it.. leave it be unless it doenst find the new burner..
Well how would i tell if pioneer 108 wont find the ASPI drivers? I guess when im looking at nero when im ready to burn something it wont show up in the drop down box?
yeah youll know.. im refering to the DRIVE not the drivers.. if they are not working properly then the drive will not show up.. in my last post i said.. if it aint broke, then i said unless it dont find the new burner.. implying that if the aspi are messed up the new burner will not show up..
GL
BTW.. if your getting a new burner im gonna take a guess and state that soon you will also be posting questions about speed etc.. if you do a search in this section youll find lots of data regarding speeds and ways to set up.. lots of good data here. -
Well ive read alot about the speed and how long things take to burn.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 04:20
