I've been given a concert DVD with some extras on. The extras play OK, but when I play the main concert, there's no sound - unless I select the next audio stream.
According to my IFO file, there are two audio streams; a stereo pcm (Audio 1) and a dolby 5.1 (Audio 2) - yet when I demux the VOB files, there is only one audio file extracted.
I've tried creating new IFOs with IFOEDIT and this does bring the sound to the concert - but it bypasses all the menus, so I can't see the extras.
Is there a way to delete the reference in the IFO file to the audio stream that doesn't exist? Or at least tell it to play from Audio2?
Thanks in advance
Sure there is. Check out 2Cool's guide about stream re-mapping.Originally Posted by HuckHound
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
