I've searched thsi forum for an answer to my question to no avail.
I had a SONY 500A burner which burned many DVD-R that were played just fine in my PIONEER 535 desktop player. So far so good.
The bad think is SONY died, and I bought a BTC 1008 which has burned several DVD+RW and a few DVD-R so far. The worst thing is that I cannot play those DVD-R in my PIONEER but I can play my DVR+RW with the same recorded material.
If my PIONEER does play DVD-R (still read my SONY burned ones) why shouldn't it play a BTC burned one?
TIA,
Results 1 to 9 of 9
BTC == Burn That Coaster
Your problem most likely is the result of BTC's poor burn quality. Perhaps upgrading to the latest firmware (758, I think??) could help...
Also try using better/different media. Perhaps +R at 4x with bitsetting? -
It could be, but (and I forgot to mention) those DVD-R play just fine in other (most recent) player. My player has 4-5 years old, which means pre-historical
Is there anything I can try to do?
BTW, I've seen that new firmware just a few minutes ago - I'll upgrade -
Upgrade done. Nothing changed.
Ideas? -
Exactly which DVD-R discs are you using?
Try using RecordNow to burn.
This may produce a more compatible disc.
Also, your drive has has the capability to do a booktype trick on DVD-R media, which will can cause the booktype to be recognized as DVD-ROM.
Use DVDInfoPro before burning for this function.WesleyTech.com - Blu-ray Disc & consumer technology news, reviews & articles -
I've used both SKY and EMTEC DVD-R disks.
This weekend I've tried 1x-4x PRINCO and everything seems to be alright.
My bad luck both types I had at home didn't work very well with this burner.
PRINCO disks ARE NOT in compatability list from BTC, but I guess it doesn't mean they are not OK, just they were not tested.
Both +RW disk I have ARE in compatability list and worked like a charm.
PS - wesociety, it shouldn't be software related as I burned +RW disks that worked just fine. Thanks anyway. -
BTC pukes up something fierce on PRINCO media. I have two 1004 drives, love them, but I feed them a steady diet of MCC, RITEK, OPTODISC, PRODISC, TYG01, MXL and others of known good quality. Few issues with DVD+R RICOHJPN media too.
Sometimes is impossible to know what media are we buying... I bought these Princo disk at my own risc, since the shop was unable to tell me the media descriptor
. These have are real "PRINCO".
I really would like be sure what are the best media on the marked, because I wouldn't mind spending 20-30% more for them. -
lordsmurf,
LG LDV-535 Remote control Codes
By Lukas2k in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Oct 2011, 20:32 -
Further Sony/Pioneer DVD tinkering
By prime in forum DVD & Blu-ray RecordersReplies: 4Last Post: 30th Jun 2010, 12:54 -
Picture adjustments on Sony & Pioneer - They don't seem to do anything
By highvolumeJP in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Dec 2008, 19:48 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52 -
Is the Pioneer 115D a straight swap for my Sony DW-U12A?
By Captain Satellite in forum DVD & Blu-ray WritersReplies: 15Last Post: 6th Mar 2008, 12:00
