I need advice for Bitrate setting in TMPGEnc when converting .vob files to mpeg2. I want the max set to 8000. What are good settings for Average and Minimum? Thanks.
.vob files ARE mpeg-2. No need to re-encode,plenty of ways of extracting the mpeg-2 video from a vob file.Originally Posted by dvdragon
If you have other reasons to re-encode, use a bitrate calculator to determine the best bitrate to use. -
The problem is Tempenc DVD Author will not take clips with a high bitrate like LOTR or Terminator 2. They show up as 9800kbps. I have to recode them. So what are good minimum and average bitrates. Thanks for responding.Originally Posted by bugster
Set the minimum to 1,000 and set the average to fill the disk by using...Originally Posted by dvdragon
Originally Posted by bugster"Art is making something out of nothing and selling it." - Frank Zappa -
If you're not worried about size then don't bother with VBR. VBR is good when you want to keep the size small (or get more on a disk) while keeping quality. In your case a high bitrate CBR will be as good or better than a VBR.Originally Posted by dvdragon
You should be able to go to 9,000 kbps total, including your audio and video. If your audio is LPCM then your video should be 7,500...set it a little lower to be safe, say 7,000."Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by dvdragonOriginally Posted by dvdragonYou are not doing yourself or anyone here trying to help you any favours by supplying the vital info in dribs and drabs like you have above.Originally Posted by dvdragon
Let us know what you have, what you want it to be, what programs you have tried and where you have run into problems. If you have been getting error messages, quote them exactly.
We'll be running around in circles otherwise
If in doubt, Google it. -
Actually the problem is Tmpgenc DVDA only looks at the mpeg header, in which the bitrate is often listed as 9800. In reality the bitrate is rarely this high. Use bitrate viewer on the vobs if you want to check.Originally Posted by dvdragon
This is only a warning from DVDA, not a fatal error. Skip it and continue. It will almost certainly be fine.
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 23:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 10:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 12:52
