  1. There is any way of delaying some subtitles..with the latest firmware, of course.
    I have some movies that have set wrong the time with about 1 MIN., so I need to adjust the display of those subs...any thoughts? Or should I wait for the next update
  2. Member LisaB's Avatar
    Use SubTool or SubCreator to adjust your subtitle file. This is not likely to be a problem with your player. Subtitles, expecially downloaded subtitle files, need to be synched with the movie file before they will work.
    SubTool is very simple and straightforware. SubCreator is more complex and powerful. Both are freeware!
