Is it just me or does anyone else get a little logo on the top right corner after converting from avi > mpeg?
It's just you
What does this logo look like? I'd like to see it.
Cheers,
ThighMaster
Its like the a square.
With 9 small square making it up into one big square.
It wasn't on the avi I converted.
And it was a SVCD conversion. -
in the past year of encodeing i never ahd a little logo on the finish product.....its just you
Sounds like the original AVI might have had a watermark...and the process of converting to MPEG made it visible.
It could be the logo of the MPEG2 codec that you have installed. For example the trial version of the Elecard MPEG-2 codec shows a logo like you describe.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
