I wanted to try out DVD rebuilder to see how effective it was. I followed instructions....downloaded and installed Avisynth, then downloaded MPEG2Dec3dg.dll and installed it in Avisynth's plug-in folder.
But each time I try to open the DVD Rebuilder .exe file I immediately receive an error message the says :
" Runtime Error '5'
Invalid procedure call or argument "
I can't get past the message
anyone have a clue?
http://forum.doom9.org/showthread.php?s=2bc767a6ec249a0c9ec329a75b0c5ebb&threadid=74308
Get info from that link I posted.
I also posted this from someone else needing help with DVD REBUILDER.
https://www.videohelp.com/forum/viewtopic.php?t=227115&highlight=
I'm too lazy and tired so check out those links. Hope they can help you out. -
well...thx for the effort. Unfortunately, the links offered no help. I can't even open/begin install because the error message appears immediately upon the attemptOriginally Posted by budz
I have been able to install other applications....DVD Rebuilder won't even begin install -
The first time I installed it I got error msgs too. I suggest you take a look at doom9's forum site for DVD REBUILDER installation guide and this other guide: http://www.afterdawn.com/guides/archive/dvd_rebuilder_tutorial.cfmwell...thx for the effort. Unfortunately, the links offered no help. I can't even open/begin install because the error message appears immediately upon the attempt
If you're not able to install DVD REBUILDER, then uninstall all the other applications first. then try installing DVD RB again then install the other applications. -
well....for general information....I discovered the problem/issue:
apparently, any versions of DVD Rebuilder after version 49 are incompatible with Win98....thus the error message
I was able to download version 49 and had no problem installing and using it. Backed-up a dvd with it during the night. I'm impressed with result. It would have been about a 40% compression with DVD-Shrink, so the quality of the encode versus a transcode is apparent.
Odd BD Rebuilder error message
By robvalentino81 in forum Blu-ray RippingReplies: 2Last Post: 21st Sep 2011, 10:08 -
BD Rebuilder Error Message MKVMERGE
By howcho in forum Authoring (Blu-ray)Replies: 3Last Post: 20th Sep 2011, 14:19 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 14:39 -
Error message with DVD Santa
By poppy56 in forum Newbie / General discussionsReplies: 8Last Post: 1st Feb 2008, 17:00 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
