Hi all.
I am using TMPGEnc Plus 2.5.
I have grabbed 15 video clips using virtual dub. I took them and converted the huffyuv grabbed avi's to mpeg 2. I then took the 15 files and merged them into one big mpeg 2 file to be made into a DVD.
The merged file has a slight lip sync issue towards the end of the mpeg 2. The 15 independent mpegs are fine.
Am I missing something?
Thanks in adavance
Joining mpegs, esp. with TMPGEnc is the cause of A/V sync problems for a lot of people. I recommend that you don't join them. Instead, you can author them as seperate tracks and there will only be a slight delay when your player switches between them.
DVD Conversion Lip Sync Issues
By waykins in forum DVD RippingReplies: 4Last Post: 4th Jun 2011, 09:23 -
DVD vob to AVI using Handbrake and lip sync issues viewing on PS3?
By GolfGTdude in forum Video ConversionReplies: 0Last Post: 13th Sep 2010, 14:53 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Having Issues with Audio Sync when merging part 1 & 2
By DVDNewb in forum Newbie / General discussionsReplies: 8Last Post: 22nd Mar 2008, 02:00 -
Sony DVD recorder and lip sync issues
By zdamons in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jan 2008, 13:56
