After waiting for 6 hours download a file someone had saved for me,
i come to find out it was saved using some program called Alcahol [sp]
on the PC. It's supposed to be a bin/cue image, but Toast won't read it...
what the heck is this, and how do I open it to burn it!?!?
Ok, never mind answered my own question.
Did a quick forum search , I see it is another in the long line
of Screwed up PC formats that do not work correctly.
A bastard version of "bin/cue" if you will.
I brought up Toast 6,
and selected "image file" on the "Copy" tab,
and then I dragged and dropped the .mdf file onto
the window.
It read it as a UDF Bridge DVD.
I clicked Mount to create a mountable image,
and it unpacked everything ( VOBs, BUPs, IFOs)
and I'm testing now with DVD Player.
Hopefully, it will burn throughly enough.
how to play mdf file
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 2nd May 2015, 11:01 -
burning .mdf to disc for chipped PS2
By kanedakaori in forum MacReplies: 1Last Post: 13th May 2009, 11:00 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 14:01 -
ISO w/ .MDF file
By 3lutz3toe in forum MacReplies: 1Last Post: 5th Dec 2007, 15:22 -
extracting vobs from mdf files
By uglijimus in forum Newbie / General discussionsReplies: 7Last Post: 15th Jun 2007, 14:15
