Hey guys, I've done a few searches but haven't been able to find an answer, so I'm starting a new thread; If this is a repost, then I apologize.
I'm having a problem with my NEC-2500A...it worked find read/writing DVDs up until a few days ago when there was a power short in my apartment. For some reason my power supply failed and my computer was shut off DVD-R mid-write session. When I rebooted my computer, the drive was still recognized but it failed to read or write any CDs or DVDs, blank or not.
Is my drive pretty much fried? Or should I try reinstalling the firmware? Any help is appreciated...thanks guys.
Try to shutdown and remove power from the computer first.
If it is still the same problem I would reinstall firmware next.
Good luck!
World -
try to install it in a different computer...make sure is the drive the problem.
if no success, then flash it again with a new firmware...this should fix the problem.
if not.....bad luck, time for a new one.
Hmmmm...I haven't had a chance to install the drive on a different computer but I did try reinstalling the latest firmare. Odd, the drive can read a CD-R disc I have, but it still won't read any DVDs I have.
Guess I should be placing an order for a 2510A soon
I had one drive with the same problem. My 3 years old son just turn off the computer power while I was burning something. When I boot up the computer, the drive cannot read and write anymore. I will try to install on different computer and flash new firmware after work. Hope this bring back my dead drive..
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 13:25 -
Imation not working in Nec 2500a
By anubis13 in forum MediaReplies: 3Last Post: 8th Oct 2007, 13:14 -
MAJOR probs w/ my NEC 2500A
By candlelight in forum DVD & Blu-ray WritersReplies: 25Last Post: 5th Sep 2007, 15:19 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 13:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
