I have installed AVISynth and the AVS reader for TMPGEnc.
I can load the script in VirtualDubMod and it works. I can see teh video and preview it with filters and changes.
When I load it in TMPGEnc I see a black video. Nothing there.
I installed the Latest Xvid and set it to YV12 color like the AVISynth FAQ showed to do. I renamed the DLL in the regsitry to XVID.DLL as they suggested. nothing works.
Any ideas?
LS
Results 1 to 16 of 16
Originally Posted by adamHello.
I missed that. But it may only be accepting it because of the AVS plugin (you don't need any plugins to load AVS scripts into TMPGenc.) The fact remains that TMPGenc can only encode from RGB sources, so if that line isn't present, adding it might solve the problem.
Originally Posted by gastorgrab
LS -
It appears to be working now. I did a capture with IuVCR and PicVideo with a color setting of YUY2. I used the YUY2 Convolution3D filter and it now works.
Here's my question. What color space shoudl I use all the time? I live in teh NTSC world and use IuVCR, TMPGEnc & DVD-Lab for my software packages. Should I do everything in YUY2 or YV12?
I still have the ghosty, jerky images after filtering with AVIsynth. i thought it was just a VirtualDubMod issue, but both frame servers do it. If I encode the 8mm analog hoem movie with no filters at all, it is fine. once I add ANY type of filter via VD or AVIsynth, it becomes ghosty on fast moving objects.
is it an issue of not enough bitrate? I'm doing 2 Pass VBR, 1000min, 2200avg, 3500max. DVD Half D1.
LS -
What did you do to get it working?
I'm having the same problem with the black screen output (also trying to use the conv3d filter) -
My capture was originally in YUY2 and I believe I downloaded the right conv3d script. There's a guide here for conv3d and it points to 2 version of the filter with instructions for which is which. Well thanks, it gives me something to try.
BTW, I've also done some 352x480 IuVcr YUY2 captures of VHS video with a decent amount of motion (Huffy compression).
I used an avg bitrate of 3000-3500 and they came out fine. The only filter I used was the noise one built into TmpgEnc (used the default parameters for it. Also used 'motion precision estimate') -
I also needed the ConvertToYUY2 line to get it working.
According to Fuliclives, the 'DoubleWeave' line given in his guide should be deleted when using PicVideo/Huffy. That probably was responsible for the ghostly images. He stated that in his guide; I just missed it. -
Originally Posted by csaag
Thanks!
LS -
I took someone's advice I saw here in another post. They found that if you start recording then hit play on the source, the field order can be messed up.
I turned the camera on and hit play THEN started recording and guess what? Top Field first.
Ran it through VDMod with filters and AVIsynth with convolution3d and bam!! Great pictures from both.
I also discovered my PicVideo was set to do "2 fields if mor then 240 lines". I disabled that and the quality was perfect!! I'm pumped now!
Thanks to everyone who kept trying suggestions after suggestions.
Thanks!
LS
Hardcoding Subtitles in MP4 not working. Megui/VSFilter/Avisynth.
By Rez. in forum SubtitleReplies: 1Last Post: 7th Dec 2011, 14:31 -
Dll Filters for avisynth 2.5 sometimes working, sometimes not
By kaskaļ in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2011, 12:32 -
AviSynth working with Y8 uncompressed AVIs and MVTools motion interpolation
By a1s2d3f4 in forum Newbie / General discussionsReplies: 6Last Post: 10th Nov 2010, 21:32 -
AviSynth is not working on Vista
By hzgg2 in forum EditingReplies: 1Last Post: 10th May 2008, 15:26 -
AVISynth MPEGDecoder audio not working
By Mark001 in forum Video ConversionReplies: 5Last Post: 8th Jun 2007, 18:30
