I am looking at buying either a used Pioneer DVR 510H or Panasonic DMR E80. Which should I buy? I am only interested in using it for its VCR capablities and not for viewing videoes from a camcorder. Which brand has a better reputation for quality? Many thanks for your replies.
I have seen captures with Pioneer 510 in this Forum. Very good!
Since you do not have much requirements such as editing features, I suggest you buy a Daytek DVR-P30. Simple to use and a lot cheaper with almost undistinguishable PQ compared with Pioneer and Panasonic if you consider the P. quality and recording time of a VCR.Sam Ontario -
If your main use will be for transferring vhs based footage, go with the Panny. Pioneer users have mentioned dropout problems when transferring some vhs tapes to the 510H.
What exactly is rotten in Denmark? -
Hi,
I have a Pioneer 510 and it works ok for VHS transfers so long as I use the VCR the VHS recording was originally made on.
As far as viewing and copying recorded material to DVD, the 510 is awesome. The editing functions work great once you get used to them. Chase play is awesome for watching live sporting events and doing your own slomo replays. Picture quality is excellent at the higher settings, and the commercial skip function is also very cool.
A solid unit, overall.
DVThe TV business is a plastic lined money trench... -
Thanks for all your replies. I think I'll just go with the recorder that's cheapest
FYI the panasonic E85 is out too. It offers picture thumbnails, 4x recording, dvd back to hard drive (re-encode involved though). I think it's the best bang for your buck for HDD recorders. Pioneer has firwire in/out and the E85 does not. Most people prefere panasonics around here.
Pioneer DVR-510H - Quite the newbie question!
By MafaldaMay in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Jan 2010, 01:13 -
Hacking Pioneer DVR-5100H (DVR-510H)
By Destroyer in forum DVD & Blu-ray RecordersReplies: 145Last Post: 5th Mar 2009, 14:46 -
DVR-510H issues with HD to DVD copying
By hobo in forum DVD & Blu-ray RecordersReplies: 23Last Post: 29th Mar 2008, 13:22 -
Firewire Output on Pioneer DVR-510H
By BroadcastTech in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th Sep 2007, 03:53 -
Pioneer 340 as replacement for Panny DMR-E80?
By LynnL in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jun 2007, 14:04
