i've created a vcd from an svcd file using the header trick but when i play it on my home dvd player the sound goes weird every now and then. when i play it on my pc dvd player it is fine, does anyone know why that is? if so, how can i fix it?
cheers!!
Well, since you've in effect tricked your player into playing something it's not supposed to, all inds of wierd behaviour might be expected... But it shold be more on the video side than audio, since VCd and SVCD audio soecs are identical - what format is the audio in? Maybe it was an off specs SVCD mpeg to begin with?
/Mats -
i probably sound thick, but i'm new to all this! how do i find out what sort of audio file it is??
There you go - AC3 is not a valid SVCD audio format - only MP2 is, and there's further restrictions too - check SVCD under WHAT IS!
/Mats
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 11:39 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 12:20
