Hi,
I´m having this problem:
I´v just encoded an avi file using MPEG 1 and then tryed with MPEG2 on virtualDubb.
During playback, the movie appears stripped, skewed and almost monochrome, running on WMP or Winamp.![]()
People who need to see the movie, would probably use these players.
Do anyone know where the problem could be?
Is there any other common recommended codec ?
Apologizes in advance, i´m almost new with video.
VDub doesn't do MPEG2 and bone stock WMP doesn't either without the codec/plugin so scratch MPEG2 and go with MPEG1. You're going to have to post more info on your source file, settings and what you've tried/trying to do if you expect anybody to be able to really offer you much help.Originally Posted by titopte
FWIW, all the way up at the top to the left under the VCD heading you'll find the MPEG1 specifications you should be targeting."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
