I have been downloading movies off morphius. They come in as avi or video files. I convert them over to mpeg with TmPGE. Then I burn them with easy CD creator 5. The movie is in two halves. Each on a cd-r in vcd format. When I play it on my dvd player, that is hooked up to my digital TV. The sound quality is great but the picture stinks. There has to be a way to get a better picture!!! Can anyone help me?? PS, please break it down in simple terms for me, I am just learning all this stuff.. Thanks
Rich
I'm afraid the old addage garbage in garbage out applies here. If you master your own VCDs from a 'perfect' source (i.e. a DVD) then you will be AMAZED at what kind of picture quality you can get. But, since you say you are downloading, I assume you are downloading in Divx format? So are taking a Greatly reduced format and then uncompressing it slightly...and whatever quality is there will degrade slightly (think copying videotapes over and over). In short, with a whole lot of fiddling in TMPGenc you can probably get a decent quality movie, but you aren't going to get high quality unless you rip from a DVD.
Mark -
i agree....if you are downloading off of morpheus, chances are they are not the best quality to begin with....i use morpheus all the time and have never found a movie with the quality that I can encode from a DVD....they compress them a rediculous amount so that they can be easily distributed over slower connections
your best bet, is doin it on your own
sorry
jvc sucks!!!
By Marvingj in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2008, 10:36 -
DV capture quality sucks
By cooldude859 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 28th May 2008, 15:07 -
Adobe Premiere Elements sucks?
By llRekcusll in forum Newbie / General discussionsReplies: 12Last Post: 12th Feb 2008, 12:35 -
Vista sucks
By Krispy Kritter in forum Off topicReplies: 1Last Post: 14th Jan 2008, 13:48 -
Why Best Buy Sucks...(and how I got screwed by them)
By midimidi in forum Off topicReplies: 9Last Post: 16th Nov 2007, 23:13
