Please can anybody help. I am trying to make an SVCD from Premier 5.1c. The source video was captured using DC 30+ with a PAL frame rate of 720x540. On exporting I have set the frame rate as 480x576 and using the SVCD preset in bbmpeg v1.24 beta 18 (upper field first) I get the following message:
Input information
Video:
width: 480, height: 476
first frame: 0, number of frames: 408
However if I set premier to 480x676 the framerate in bbmpeg is somehow registered as 480x576 and can be used in burning packages. However the video output is stretched (presumably because it is 480x676) Does anybody know a way to correct this flaw in bbmpeg since premier frame output is unaffected when I use other applications.
PS I have downloaded various versions of bbmpeg and the problem persists.
Results 1 to 1 of 1
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45
