I am very unhappy with the indoor performance of my TRV38 because of the light streaks that seems to radiate from normal light sources indoors. It makes the camera video almost unusable when shooting indoors. does anybody have any suggested fixes for this problem? Please look at the below note:
I think all the Sony CCDs, particularly those used on the 19/22 (using the identical CCD), and the one used on the 33/38/39 (I think identical CCD) are HAD (=Hole Accumulation Device). Note that the "HAD" design does make for more light sensitivity, but if misused can cause a bad defect - the "Alien Spaceship Beam". This happens if there is a bright light source "shining" on the top of the CCD and shows up as a vertical blurry bar. The lightsource does NOT have to be "in the visible part of the imagery", it can be just "above" the pixels used for actual imagery and in the border pixels (used for motion compensation).
MitchellFox@comcast.net
Results 1 to 1 of 1
white streaks, black streaks, comets, dropouts
By jmac698 in forum Capturing and VCRReplies: 6Last Post: 8th Mar 2012, 09:07 -
8mm black streaks
By mark23 in forum RestorationReplies: 15Last Post: 13th Feb 2012, 10:10 -
Sony Handycam - streaks in both LCD and viewfinder
By hermmona in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 4th Sep 2010, 10:48 -
Capturing NTSC - Streaks
By davis7 in forum Capturing and VCRReplies: 7Last Post: 23rd Aug 2007, 05:15 -
Where are these black streaks coming from? *PICS*
By JimboJonesTX in forum RestorationReplies: 2Last Post: 14th Jul 2007, 15:13
