  1. Hi,
    I'm trying to author a game with DVDAuthor under windows.
    There are different pictures in 6 titlesets and lets say 23 pgcs per TS.
    In VMG I check value of a register and then jump to adressed TS.
    Then in TS I check value of another register and jump to PGC.
    Works fine but cannot jump to PGCs beyond 99 in total on DVD.
    in this example means can jump to PGC #7 in TS 5 but not to #8
    in same TS. Ifoedit says "illegal navigation command encountered"
    Has anybody managed to work with more than 99 PGCs?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Not sure on this, but the DVD spec might not allow for more than 99 pgc's?
    /Mats
  3. Originally Posted by mats.hogberg
    There is a limit 99 on amount of TS and other apps support a lot more PGCs on DVD.
  4. Free Flying Soul liquid217's Avatar
    Feb 2002
    vion11:
    http://www.dvd-replica.com/DVD/vtsguide.php
    According to this: only 99 titles are allowed under a titleset. I am unsure if this is accurate information though. You might run this by the dvdauthor mailing lists. By the way, excellent work on the tic-tac-toe game.
  5. Originally Posted by liquid217
    You are right, but I run into a max 99 title per DVD limit.
    Which is less then 1% what specs allow,
    because not every PGC must be a title.
    And THX, it is still TicTacToe I'd like to finish with DVDAuthor.
