i would like to add french language to an english dvd. i have the english dvd and the ac3 french language. please help!! i have done a bit of search and i beleive i would have to use ifoedit which i downloaded but don t quite understand how it works!! thanks for any help
laurent3185,
Welcome to VideoHelp.
If you check the guides section, you can search by tool - it's a very useful feature. I found a relevant guide for you:
http://www.photosyndikat.de/guides/MultiAudio.htm
Best of luck with your project!
Cobra -
thanks cobra i ll have a look but i don t have much hope as i looked through the forum and it seems pretty tricky to do!! but if anyone has a simple solution please let me know!!
Keep bashing away at it, follow the guides. If you get stuck or have questions, this forum is only a few clicks away!
Cobra -
thanks again cobra but there is no way i m going to attempt anything following the page you mentioned
is swapping english for french easier???
cheers
Adding extra files to DVDs
By kinglerch in forum Authoring (DVD)Replies: 2Last Post: 21st May 2010, 12:59 -
Adding extra folders or files to BD Disc
By jntaylor63 in forum Authoring (Blu-ray)Replies: 2Last Post: 2nd Feb 2010, 13:48 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Adding extra data folders to DVD
By schematic2 in forum Authoring (DVD)Replies: 6Last Post: 25th Apr 2009, 11:01 -
re-author DVD adding a new subtitle language?
By u2paddy in forum Authoring (DVD)Replies: 2Last Post: 19th Apr 2008, 18:05
