Hi againNeed some help with this too....
As our TV format is PAL, I got almost all of my stuff on PAL format on VHS, and so I'm getting all PAL MPG compliant files out of them, but need to burn them on NTSC format since my TV is PAL N / NTSC (and so it'll play the VCD in black and white if I don't convert the MPGs into NTSC format before I burn them).
Any help? Just name the program that will do that . Thanks so very much
Seriously bad idea. Converting 25 fps to anything else is a bitch. Good luck finding a tool that will do a good job of it; TMPGenc certainly won't.
My DVD player plays back PAL stuff in NTSC format, as far as I know, most of'em do. Unless you like jerky video, go buy a better DVD player.
Burning several mpg files straight to a DVD compliant disk...
By vonsworld in forum Authoring (DVD)Replies: 2Last Post: 5th Dec 2010, 06:25 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Best way to convert avi to MPG DVD Compliant(highest quality)
By andre477 in forum Video ConversionReplies: 19Last Post: 25th May 2007, 04:59
