Results 1 to 17 of 17
    Jun 2004
    San Diego, CA.
    Wow... I think I have all of my ducks in a row, but it looks like TMPGEnc wants 21 hours to re-encode! My CPU is an AMD 2500+ Barton, 512MB RAM Does that sound right, or is there maybe something horribly wrong in my settings?
    Also, the little window that shows the frames crrreeeeppping by as it encodes is 4:3 The Video tab says 16:9
    http://www.john-oliver.net/screen1.gif
    http://www.john-oliver.net/screen2.gif
    Is there any way for me to be sure I'm going to get anamorphic 16:9 out of this thing if I let it go for 21 hours?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    How could anyone tell, without knowing your settings? 21 hrs seems mighty long, unless the movie is a day or two long, or you haven't set the motion search precision to highest and/or are using lots of filters.
    Yes, by encoding just a minute or so, checking the result, then, if all seems well, encode the whole movie.
    /Mats
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by jnojr
    the little window that shows the frames crrreeeeppping by as it encodes is 4:3 The Video tab says 16:9... ...Is there any way for me to be sure I'm going to get anamorphic 16:9 out of this thing if I let it go for 21 hours?
    Go to the options menu. Go to Preview Options and I'll bet that "Fix to 320x240" is selected. This is why the preview you are getting "appears to be 4:3". As long as your template settings were correct, you will be OK.
    Good suggestion though to give a small sample a test run to prove it to yourself.
    If in doubt, Google it.
    Jan 2004
    Middle of England
    My CPU iS a AMD 1.3 Duron and it takes me 7-8 hours to encode a widescreen MPEG2 121 min film, got the same amount of memory as you as well, 21 hours seems way to long you need to check your settings again.
    Oscar.
  5. Member rhegedus's Avatar
    on the jazz
    Are you running any filters in TMPGEnc?
    Regards,
    Rob
    Jun 2004
    San Diego, CA.
    jimmalenko - Yes, that option is checked.
    rhegedus - If by filters, you mean the .mcf files, then no. I started TMPGEnc, cancelled out of the Wizard, loaded unlock.mcf, put in my video and audio source, and set my Settings. The settings are:
    http://www.john-oliver.net/screen2-1.gif
    (I tried a couple of different things)
    http://www.john-oliver.net/screen3.gif
    http://www.john-oliver.net/screen4.gif
    The encode time still says it's going to be 20-someodd hours. What else can I look at?
  7. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    2-pass vbr will double your encoding time, and the noise reduction filter that you checked will do that as well. Sounds like your encoding time is about right.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Echo this. I found the noise filter more than double the times, more like about 4X.
  9. Member LSchafroth's Avatar
    Dec 2002
    make sure to set your temp sapce in the Environment settings to at least 4.3Gb for the 2 pass. It will save a ton of encoding time.
    Would it be faster to filter with AVISynth or VirtualDub? I don't know how fast they are in comparison to TMPGEnc's built in filters. Anyone?
    LS
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Do you mean make sure that the drive that your temp file will be stored on has at least 4.3GB free ?
  11. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    No. In TMPGEnc>environmental settings>cpu, set the cache to 4 GB.
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    OK. By default mine is 4096MB - that OK ?
  13. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Honestly, I dunno. A post from a long time ago said that 4 GB seemed to be the best and that any more didn't make a difference. I've been using that ever since.
    Jun 2004
    San Diego, CA.
    Thanks for the info about the noise reduction and 2 pass.
    How useful is the noise reduction? I'm going to try encoding without, and see what it looks like.
    Also, about this cache setting... when I go to Environmental Settings -> CPU, I don't see it...
    http://www.john-oliver.net/options.gif
    It isn't under the other tabs, either.
  15. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    i think you're using an old version of tmpgenc.
    Jun 2004
    San Diego, CA.
    I'm using 2.521.58.169 that I downloaded from tmpgenc.net maybe a week or two ago! How could I have an "old" version? Where should I download the correct one?
  17. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    i'm using 2.521.58.169 as well, and i see
    perhaps it only shows up in the full version.....?
