Results 1 to 11 of 11
  1. I'm using TMPGEnc 2.5 (don't need anything from the later versions so far) and was wondering if there's any way to reset the 30 day counter for MPEG-2 encoding. As far as I can tell, the only way to get permanent MPEG-2 recording is to buy a lter version of the software, which is pricy and I don't need.
    Also, is there any good way to de-mux DiVX files and then mux the mp3 audio back into an MPEG file so I don't have to re-encode the audio?
  2. Banned
    Aug 2002
    beautiful
    Youre asking for hack... I dont think it is the right forum for this kind of question...
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yes...there is.
    Pegasys will unlock it for you when you BUY IT.
    Seems to me like you DO need it, otherwise you wouldn't want MPEG-2 "recording" in the first place.
    Ahhh, finally a legitimite question.
    I don't think there is (I am not aware of) a way to do what you would like to do, only because I don't think MPEG video and MP3 audio can go together.
    If in doubt, Google it.
  4. If you want free MPEG-2 encoding, download BBmpeg. You may want to read the forum "rulez" and edit your post accordingly before you get a warning....
  5. I don't mind paying, I just don't want to have to pay for a full upgrade. The only premium feature I'm interested in is MPEG-2 recording. BBMPEG does nothing but crash when I try to use it.
    Never mind. Just saw TMPEG2.5 Plus is much cheaper than I thought. At any rate, I think I'll hold out to get a DVD burner. If that comes with decent software, I won't need to purchase anything.
    And what's the deal with mp3s? It's a MPEG audio format that can't be used with actual MPEGs? (I apologize if this sounds like a newbie question.)
    Also, so I don't have to buy 2 encoders, is there any way to do rm with TMPGEnc?
  6. Originally Posted by Ace_of_Sevens
    Realmedia can be done with realproducer or fx video converter. TMPGEnc will not do RM. I havn't done anything like what you are trying to do, so I really can't comment on the rest. There is also Quenc but I can't remember if it does MPEG-2 or not... Look under tools.
  7. @Ace_of_Sevens
    I made once a VCD with mp3 track. It was multiplexed in TMPG as non-standart VCD and for my surprise it played in my DVD player (Schneider DVD V 300 - Mustek clone). It needed more time to load the disc though.
    As for mpeg-2 I will suggest to use MencodeMe - this is what I am using.
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    mp3 is not a valid audio format for any disc based video (VCD/SVCD/DVD). Some players might play such a non standard mpeg anyway, but don't bet on it.
    /Mats
    Dec 2002
    My Swamp
    MPeg 2 encoding IS the premium feature
    This is the real world. Things like burners don't come with decent software. If they have a decent program it's usually a very cut down or a trial version.
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    There are other features ?
    The bolded bit is wishful thinking, don't you think ? I have never yet seen a full version of a decent program bundled OEM....except maybe PowerDVD. Certainly no encoders anyway.
    That IS a newbie question. Read What is DVDR (top left) to see the specs on what is acceptable for DVD.
