Hiya all, i recorded my mates band playing their first gig the other night i recorded the sound separately to the video.
Now the video ive got no problem with, how do i add the sound which is in mp3 format to the video avi and get a perfect sinc??
do i do it in virtual dub? been looking cant seem to find anything, can anyone point me in the right direction please
The video is in avi format, dont really care what the output file is i can always convert it later.
Im fine with converting both separately
All i need to know is how to add the sound to the videoif i put both streams in tmpeg its gonna be very badly out of sync.
how can i change it to make the audio in sync
cheers -
First, find out how much out of synch the audio is. Load it into Gold Wave, add the silence or delete the extra audio. Save as a wave file. Load the original video into Virtual Dub, select Audio=>Wave=your new audio file. Save under a new file name, which, of course, contains the new in-synch audio and video.
Hello. -
Load the avi into virtualdub and then load the wav you just converted into audio/wave audio and choose interleaving in the audio menu and input the amount of +/- delay into audio skew correction,then play the avi with virtualdub and see if the audio matches the video,if not go back to interleaving and keep adjusting till you get the results you want and then save avi as,make sure video is set to direct stream.Doing it this way you dont have to keep opening and saving in virtualdub.
Synchronize Audio and Video from Different Sources
By Bruno AUgusto in forum AudioReplies: 2Last Post: 22nd Nov 2011, 18:27 -
How to combine *.264 video + *.aac audio to one file?
By video-fan in forum Video ConversionReplies: 5Last Post: 18th Oct 2011, 02:38 -
How do i combine a video file and audio for two different movie sources??
By Kyisha in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2010, 06:03 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
