Am ripping the audio using Azid Gui integrating toolame, wavebooster and ssrc, however I get a no such file (or similar) error message during the process, I have set up the program locations for each program, and everything goes fine, it test gain levels and completes the next step, then it all goes wrong. I suspect that the problem is that the following programs, toolame etc do not know which file to open to do their bit, do I have to set a source file location under each tool section and resulting file or will this information be passed automatically from the file locations on the first setup screen of Azid Gui. If I have to set up the files at each step of the way, do I use the written file name in the previous task as the source for the next task, ie
test ac3 t01 3_2ch 384kbps delay -96ms.ac3 becomes test.wav, therefore ssrc should be told to open test.wav and write to test2.wav which in turn is opened by waveboost etc...
Getting down to the last few hairs to pull out now![]()
