Hi
Another newbie pestering you guyz
Iwant to do a backup of my terminator 2 dvd but keep top quality
Which tutorial do i use so a to keep the menus and spread the the film over 2 disks
regards
clonedvd2,or follow this link to use dvd shrink
https://www.videohelp.com/guides.php?guideid=481#481bmiller,ont.canada -
you are not going to keep the menus if you use Shrink to split dvd over 2 discs.
I use dvdshrink (found at www.dvdshrink.org) to backup a lot of DVDs, and at first I decided to do just the movie, like you, to keep as much quality as possible. I then tried backing up the whole DVD, and having dvdshrink "shrink" it to fit..I was amazed at the quality of the video. I'm VERY picky and have a 61" TV and I can't tell at all that it's been compressed. Something else you can do to get even more quality is highlight the main movie, choose Custom Ratio in the video box, and slide the compression slider until the movie is at it's max while still fitting on the DVD. This will compress the extra features that you probably won't watch as much as the movie.
If you want to get your hands dirty for free, IFOEdit can do the job for you.
What is it with people that want main movie and menu ?
You put the DVD in, it fires up the menu, you then can only click on Play Movie or use Scene Selection because no other buttons work
OR
You put the DVD in and the movie starts playing straight away. Scene Selection is clicking the Next button
I know which one I'd choose.If in doubt, Google it. -
Hi
Yore probably right in most cases
But for the odd movie and for educational/knowledge purposes
I wanted to be able to do it
AND
now I know I've managed to do one
TERMINATOR 2
different soundtracks and sound setup from menu etc
See Yah
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 01:50 -
How do I backup this movie and maybe change menus?
By leopardx in forum Blu-ray RippingReplies: 3Last Post: 6th Jun 2009, 11:10 -
Backup DVD can't be read normally, menus don't work
By chtit_draco in forum DVD RippingReplies: 7Last Post: 18th Apr 2009, 10:30 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07
