I have read some of the articles by Micheal Tam at the vcdimager site. Also have read vitalus' post here. What I want to know is BEFORE I start to demux and insert closed GOPs to a mpeg. Is there any way or any software that will tell me if the file already has sequece headers and thus can be chaptered with something like VCDImager or VCDEasy.
I guess I should explain. I have several cds with raw video streams of things that I have shot myself with an analog camcorder and converted to avi with my ATI all in wonder card. I then converted these to mpg-1 with TMPENC and burned them onto cd using EZ CD recorder. They play just fine in both my computer and DVD Stand alone player. I also have a lot of mpeg files that I have downloaded from the internet and that I either converted to vcd format(mpg-1) I or came that way already. No problem playing them in the computer or DVD.
Now I would like to make real VCD's with chapters and menus e.t.c I understand how to do this. I have read the guides from VCDEasy, here at this site and at Micheal Tam's site. The thing is, from reading all that stuff I have determined that that mpeg has to have sequence header(regular or otherwise) in order to be chaptered. I know I can use MPEGSEQUENCE maker OR TMPENC to do that, but I would hate to go thru that if they file already had the headers in it. Is there anyway to tell?
Easy.
MPEG1 files don't have GOPs at all because GOPs are part of MPEG2 specification.The more I learn, the more I come to realize how little it is I know. -
Not sure what SaSi meant but the GOP structure in MPEG1 is (almost) the same as in MPEG2 (MPEG2 is a superset of MPEG1).
If you had the "Output interval of sequence header" (under GOP structure) set to 1 when encoding with TMPGEnc then you have a sequence header for each GOP.
If you're not sure, run the video through an MPEG parser (DVD-Lab has one) and you'll see. -
What I meant is that (I could almost swear) that MPEG 1 doesn't have a GOP sequence header structure.Originally Posted by petar
Well, I am wrong.
Yesterday was a bad day to post replies. It's been a year since I read the MPEG1 specs and I forgot that MPEG-1 has GOP headers as well in the stream.
Well, what I meant, (if I understand myself correctly), is that any encoder encoding MPEG1 would most likely avoid placing GOP headers as GOP headers are only required for DVD.
Same like encoding for SVCD. Video typically doesn't include GOP headers making the video invalid for DVD (apart from the frame size which can be defeated by programs that modify the sequence header).
In any case, ignore my posting
It's the heat
I'm too in Southern Europe (Spain) it's over 30 degrees here in the morning.
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
I have a .mpg file that I need to demux I want the audio..
By J Tinsby in forum Video ConversionReplies: 6Last Post: 23rd Jun 2011, 18:20 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
demux DVD Video to MPG!
By GangstaRap in forum Authoring (DVD)Replies: 10Last Post: 8th May 2007, 17:45
