What is the best software to use to convert downloaded mpeg4 (mp4) to avi or dv so I can edit it? I use Edit Studio 4.
I don't know if its the best way but....
You could install 3ivX trial and use Graphedit to decode to uncompressed AVI.
I've tried to remux to Matroska (MKV) but i occasionally have trouble with the mp4v FourCC code. Changing it to XviD doesn't seem to work, but changing to DivX makes the video stream viewable in VirtualDubMod.
The audio stream i've never had much luck decoding with anything other than the 3ivX decoder.
If you have QuickTime Pro, then you can export MP4 directly to AVI, or DV-AVI.
If your willing to try the TMPGEnc trial, then with 3ivX installed, you can open the MP4 by choosing "All Files" and then export the AVI through "File / Output to file / AVI file".
Convert MP4 to AVI?
By JS12 in forum EditingReplies: 0Last Post: 22nd Jan 2011, 08:58 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
[How do I] Convert MP4 to AVI
By supe2 in forum Video ConversionReplies: 1Last Post: 14th Dec 2010, 06:47 -
Best software to convert VOB to mp4 or AVI, or AVI to MP4?
By 80zforever in forum DVD RippingReplies: 7Last Post: 18th May 2010, 12:32 -
how to convert FROM MP4 to avi etc.?
By neutrino78x in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2007, 05:09
