Topic!![]()
M2v is typically mpeg2 video, mpv can be either mpeg1 or mpeg2 but from your post I'm assuming you are just having difficulty with mpeg2 sources.
If you go to environmental options/VFAPI plugins and increase the priority of the direct show file reader plugin, they should load. But this is a horrible way to encode mpeg2 sources.
You should frameserve instead. Just load the file in dvd2avi and hit file/save project file. It will create a d2v file which you can load in TMPGenc. This provides a stable way for TMPGenc to access the video source. -
or
http://www.marumo.ne.jp/mpeg2/m2v_vfp-0.6.47.lzh
(there's another link around here somewhere to a zipped version.
look for m2v_vfp-0.6.47.zip)
supported read formats:
How does one process mpa and mpv files?
By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 14:30 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
can't play .mpv files with sound
By gbabione in forum Video ConversionReplies: 10Last Post: 23rd Nov 2008, 12:10 -
Can't open older TMPGEnc DVD Author files in latest version
By steelborn in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2008, 14:55 -
Cannot open wav files in Tmpgenc
By deadlycow in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 03:54
