  1. i have a strange problem : i reinstalled winXP (after formatting) on a friends PC (P4 2G) and now after everything else works just fine it won't play DVDs anymore ? before everything worked perfect ! it plays DIVX (haven't tried MPG1/2 - the only software he has is WINDVD which worked perfekt before reinstalling XP)
    when i try to load a DVD WINDVD closes directly after 2-3 sec (mediaplayer does the same thing) - also with ISO-files using nero image drive (so it's no DVD-drive problem)
    ...i already uninstalled and reinstalled WINDVD (will try other software these days)
    what went wrong ??? any ideas out there
  2. I had a similar problem (Windows 2000 though) after a reinstall and fixed it (not exactly sure why) by installing forceASPI which you can get here:
    https://www.videohelp.com/tools?tool=24#comments
    Same symptoms desn't mean the same problems but maybe worth a try?
  3. ...thanxalot ! i'll check it out as soon as i can and let you know what happened...
