i used my dvdxpress to capture a 2 hour long movie from vhs. I have tried to use 2 different programs (dvd architect 2 AND dvd moviefactory 3) to get it onto dvd with no menu. just the movie itself. with both programs, the audio is fine for the beginning of the movie, but by the end, the sound is about 1.5 seconds off from the video. i have used this exact method before with no problems. the captured video is 720x480, 6000kbps, layer 2 224kbps. these are the same settings that worked for me before. any thoughts?
Dropped frames maybe?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Is the video out of sync on your PC or DVD player?
This plan is so bad, it must be one of ours. -
wht is ur system spec? before you tried to change the file, was the pc on before tht, if so how long?
Is the Dvdxpress plugged into a USB 1.0 or USB 2.0. I ran into a problem using mine in the USB 2.0 when running a Athlon 1.2 GHZ. When I upgraded to a AthlonXP 1.8 I was able to use the USB 2.0 connection without any problems or dropped frames. Have you used the cap wizard program that came with dvdxpress. I have had better results with it then with Video Studio 7 or Sonic MyDVD.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
AutoGK, Audio Sync problem.
By steve_hawthorn in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 01:39 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 16:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 07:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 11:26
