  1. hi
    i want to create dvd menu to data dvd ( or dvd-iso ).
    when i play such disc in my dvd player i get list of files ( mpg , mp3 ... ) and i can play them.
    i can't find any program that create menu without converting the video files to video dvd ( i want them to stay in vcd format ).
    thanks for any help
    shay
  2. You cannot do that. However, VCD video is allowed on a standard DVD.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Just because it is mpeg-1 encoded doesnot make it VCD compliant, and therefore suitable for use on a DVD. Similarly, mp3 is not a DVD compliant file type. While some stand alone players will recognise mp3 and other file types on a data DVD, they will not recongise them on a video DVD unless they are compliant and authored correctly.
  4. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    It can be done, but for PC only. You cannot do it on a standalone. Actually, the way it can be done is not the same as authoring. It is Basically a menu program that runs the menu from Autoplay.
