convert ogm file to avi
any help much appreciated
1. start vdubmod
2. drop OGM in it
3. audio (streams/stream list)
4. demux OGG audio (select track to demux, click demux)
5. use a utility to re-encode OGM into MP3 (I used dBPower AMP Music Converter)
6. in vdub mod, disable the OGM track (click disable button)
7. add MP3 track
8. close streams dialog box
9. go to video menu and make sure to set it to "direct stream copy"
10. go to file/save as, choose AVI as file type, and give it a name. -
I have the same kind of file only it has embedded soft subtitles. I usually use AVI-Demux to rip the subtitles from the file. Since the subtitles aren't listed as a stream in Vdubmod, how do I get it so that TMPGEnc won't convert the subtitles too? I'm trying to create a DVD that can have selectable subtitles? But everytime I open TMPGEnc to convert it, Vobsub just appears automatically and the subtitles are transferred.
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 12:19 -
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 01:56 -
Newbie want to know how to convert OGM file to AVI
By mody in forum Newbie / General discussionsReplies: 2Last Post: 14th Mar 2008, 14:59 -
Convert ogm to avi please?
By venus in forum Video ConversionReplies: 13Last Post: 11th Aug 2007, 18:15 -
How do I convert .ogm file to .avi and keep a certain audio track?
By Moldiver in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 09:43
