Ok, I checked through a few threads and I believe I know the answer to this. But I must explain directly what I want to do. My neighbor asked me to put a 8mm home movie on a DVD. I figured, no problem. That is until she told me she was sending it home to the UK. I'm in Japan. My initial idea was to simply capture at 352 or 720 X 576 and letterbox the areas between 480 and 576. I am assuming she has an NTSC camera. Aside from the resolution, I would just capture at 25 fps instead of 29.97. But something tells me it can't be that easy. How should I handle this?
UK equipment can play back NTSC without a problem , so you should be OK without converting to PAL.
He's in Japan?....Tape is going to U.K.?
OK....NOW I get it.
Yep....skip the conversion process....it's not worth it. The U.K. stuff will play it reasonably well. -
Just capture as normal NTSC and then after you capture (hopefully to an AVI format) then you can convert to PAL if you so wish.Originally Posted by fmctm1sw
You can't capture NTSC with PAL settings ... it just won't work right.
Belive it or not mainconcept pvr captures 720x480 at 25fps from NTSC... a sort of hybrid...Originally Posted by FulciLives
But, this is a different story...
8mm Pal to NTSC
By GR8LAKER in forum Newbie / General discussionsReplies: 3Last Post: 16th Mar 2011, 08:48 -
8mm tapes PAL with NTSC camcorder????
By igorv in forum Capturing and VCRReplies: 5Last Post: 11th Oct 2010, 14:17 -
Convert PAL 8mm tape (Hi8, Video8, Digital8) to NTSC DVD
By scotty123 in forum Video ConversionReplies: 0Last Post: 9th Oct 2009, 13:49 -
By scotty123 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 01:34 -
Record 8mm Home Movies w/Digital Camcorder?
By stahlhart in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2007, 16:28
