  1. The new encoder version 3.0 XPress does not seem to have this option. I am converting video shot on my DV camera to DVD and the output is noticeably washed out compared to the source tape. I have resorted to using filters to reduce luminance and red levels slightly to try and match the original video. I previously tried v2.5 of the encoder on a trial basis and enabling the 'Output YUV data as Basic YCbCr" setting helped a lot. Does anyone know where this setting is in the new version or if there is any other setting for reducing luminance other than messing with the filters?
  2. Tmpgenc 3.0 does not have the "Output YUV data as Basic YCbCr" option, and you are correct, it does produce washed out video. As I commented in another thread, it will shrink 16-235 to around 30 (32) - 218 - useless unless one resorts to filters to expand the luma, etc.
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    This is why I switched to using pretty much nothing else now but Cinema Craft Encoder as you don't have that problem (i.e., screwed up luma).
    - John "FulciLives" Coleman
