  1. I have been using this board for nearly 6 months but I have observed a particular phenomena which I am not sure whether this is normal or not. When I switch on the UPS, I observe the following:
    1. The two LEDs on the cabinet glow momentarily and go out.
    2. The Processor fan rotates for few secs and stops.
    3. The LED on the mainboard glows and remains lighted.
    4. The LEDs of CD-Drive, CD-Writer also glow for few secs and go out.
    5. The Cabinet Fan also rotates for few secs.
    Next, when I switch on the Power button on the cabinet the Computer boots normally as any other PC.
    I have doubts about the sudden activity of the Processor fan, Cabinet fan, LEDs of Cabinet, Drives etc whether this is normal. I have never encountered such thing in my earlier boards. Recently, my new Pioneer DVD Writer DVR106 stopped working after use of 2 months. I think this sudden surge of voltage through the mainboard when the UPS is switched on is the culprit.
    I have replaced the SMPS thrice and the same results.
    Are there any members using this particular mainboard ? Do they find the same phenomena ?
    The PC specifications:
    Pentium 4 2.4GhzC
    D875 PBZ
    1GB Memory PC3200
    4X 32MB AGP
    Creative SBLive 5.1
    Samsung 7200 rpm 40 GB
    Samsung 5400 rpm 40 GB
    Samsung 1.44 MB FDD
    Samsung 15 " monitor
    Mercury 1000W(PMPO) speakers
    Mercury 300W SMPS
    APC 0.5 VA UPS
    Samsung CD-Writer 52X
    Samsung CD-Drive
    Win XP Pro
    vsenapati
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Sounds like what happens when you bleed your caps after disconnecting power from the machine. Immediately after shutting your machine down unplug the power cord from it and hit the power button. Does it do the same thing that you're describing then? If so you may have something wrong with your power supply. Are there any other devices plugged into the UPS that are connected with this computer?
  3. I recently received a reply from Intel Support and they have informed me that the phenomena which I had observed is absolutely normal. This happens everytime the UPS is switched on and the mainboard receives power before the Power Button is pressed next.
    I am really relieved now.
    vsenapati
    Dec 2002
    Costa Rica
    I have Dell computer with the same chipset as your mobo and it has the same behavior.
    This is perfectly normal.
  5. I am happy to hear from you that you have been observing the same in your DELL pc and its absolutely normal. Thanks!
    vsenapati
