1. dvddecrypter
2.dvdshrink
3.TMPGenc DVDauthor
voila!
BUT !!!!
no subs with step 3.!!!
Ive now got like 20+ proggs on my system but nobody can do it it seems !
I only want to have a simple playbutton in front of my main movie !
AND i dont want to be working hours on end with muxing demuxing subs and streams !!!
I want it to be simple and fast ...
But im afraid this is asking to much huh ?
Anybody ?
BIG TNX!
Yes!
ILL need dutch subs playing auto and a start button to play all.
NP if youre english but ...
ripping is no problem
shrinking is no problem
authoring is no problem if you dont need subs
BUT i want subs !!! -
Well, you answered your own question: you need another authoring program! The one that supports subs! There are lots of them! And each would require hours of muxing demuxing the subs and streams!Originally Posted by AntiAlias
BUT!!!
There is a way around it: if the original DVD has the subs you want, don't re-author it! Just compress it with DVD Shrink or CloneDVD, etc. and that's it! -
And, you can always just flag one of the subs as default.
And you don't need a "play button". Pushing "play" at the main menu ALWAYS plays the movie. ROFL.
- Gurm -
Hi all.
AntiAlias, simply use DVD Shrink "Re-author" mode.
Right-click on the movie-title to access a menu.
Use the "Set Default Streams" sub-menu to select the subpicture stream you want to appear automatically.
No need for a "play" button.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
