Hi,
I ripped one clip from a DVD. It's a 16:9 aspect ratio.
Then, used TMPGEnc to encode to SVCD NTSC.
1 - I encoded two new clips. The only setting that was different was the Aspect Ratio (in the Video Tab of TMPGEnc). I think this setting refers to the output file. In the Advanced Tab the setting of the aspect ratio is 16:9 (as this is the source aspect ratio) for the two clips.
The only change was:
clip1 - aspect ratio (Video Tab) - 4:3;
clip2 - aspect ratio (Video Tab) - 16:9;
What I got (using PowerDVD to play the clips):
clip1 has top and botton black borders (it's ok) and looks better than clip2;
clip2 has not black borders and the screen is bigger than the clip1, but I notice that the image quality of clip1 is still better.
The difference of the file size is only 3MG.
Shouldn't clip2, at least, have the same image quality as clip1?
2 - For the audio I used TMPGEnc with the option of using external engine like Toolame. Is this a good choice or could it be better?
Results 1 to 1 of 1
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 22:10 -
Ripping DVDs as MPEGs using TMPGenc --- loss in quality?
By DieselsDen in forum DVD RippingReplies: 5Last Post: 21st Sep 2010, 13:09 -
TMPGEnc advanced settings for best quality results
By tdavid232 in forum Video ConversionReplies: 1Last Post: 15th May 2008, 19:02 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 13:15 -
What are the current encoders comparable to tmpgenc in quality?
By inuyasha in forum Video ConversionReplies: 24Last Post: 26th Jun 2007, 06:43
