I can't find the cabling answer i need..
I've bought a Daewoo T267 PAL VCR, and the only output that i can see is the coaxle. I'm in NTSC land.
My only capture option is with a composite (ATI 64mb ddr VIVO card).
Is there any adapter out there, that will alow me to transfer the coaxle to composite signal, or am i shit out of luck??![]()
I have two composite cables for front use, but it seems that they're for input only!!
Thanx...
Results 1 to 11 of 11
I only see two options: Run the coax out into another VCR or into a tuner capture card. Both will degrade quality. If you bought it used, you could open it up and unplug the input to the TV modulator and use the inputs to that for composite video and sound out. (If it is a separate module.)
redwudz wrote:
Unfortunately, the two different diameters of coaxle don't allow this..Run the coax out into another VCR
Heck, i can't even pronounce modulator, but i'll give it a try. Sounds too good to be true..use the inputs to that for composite video and sound out.
Thanx, appreciate the response... -
I won't make you any promises, but it you take up the screwdriver... Open the case and look for a small silver box, about 2-3 inches in diameter. If you are lucky, it has a short RCA cable going into it. And hopefully an audio input which may be different. The modulator output will go to the coax jack on the back. If you can plug a RCA female end into the short cable then you can see if the output is composite by plugging it into your composite in on the computer (or the composite in on another VCR.) The audio will go into the modulator also. There should be both a power(DC voltage) input and an audio input wires. If you don't see the silver box and obvious cables, may be to hard to do much with. Good luck!
Uhhh... you do know that there are modulator/converter boxes that will convert a coax cable input to an RCA type output. Hell, I just found one the other day at a thrift store for 2 bucks!
Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
God, I hope you can prove me stupid..I phoned 4 different radio shacks, for such a thing, an none of them heard of this..Uhhh... you do know that there are modulator/converter boxes
On a side note, i noticed that the PAL coaxle has a larger diameter male plug, than the NTSC female plug..
I'll keep pluging away..I'd rather keep this unit than put it back out on Ebay...
Fingers crossed... -
Are you really sure there is no SCART on that machine?
When I search for the specs it says:
VCR T267
2 x EURO-AV-SCART
So better take a good look again... -
There's scart, which i was told was useless in NTSC land, but have come across http://www.satcure.co.uk/tech/scartext.htm.
Forgive me, i've never even heard of this term..
It's looking promising..
I'm phoning locally, but no PAL modulators..
Fingers crossed.. -
Just get a SCART lead with standard composite/audio connectors.
Don't mess with modulators, It will degrade the picture quality and give too much problems. Not worth the trouble. A PAL modulator in NTSC land is also no fun I think.... -
Alrighty, this is new to me..Just get a SCART lead with standard composite/audio connectors.
I'll search for a scart cable here, and if i find one, i owe you a beer.. -
this is what you need!Originally Posted by pijetro
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 12:54 -
How are DVD camcorders for editing their ouput?
By brassplyer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Aug 2009, 01:16 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47 -
PAL VCR with true NTSC Output (not PAL 60)
By Area88 in forum RestorationReplies: 31Last Post: 12th Aug 2008, 18:55 -
APEX AD1250X stuck in PAL mode cant switch back
By sysman0 in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 23:04
