  1. Member Sakuya's Avatar
    Dec 2002
    Hi. I want to convert an AVI to MPEG-2 for DVD. When I play my AVI in Windows Media Player, the video and audio plays fine but there are occasional color blocks appearing on the video. Pretty small. I use FFDSHOW. And here is GSpot's notes on the AVI file:
    Video Codec: DivX 3 Low-Motion
    In FFDSHOW under Supported Codecs, I have the following enabled:
    XviD
    DivX 3
    DivX 4
    DivX 5
    FVFW, FFDS
    MP43
    MP42
    MP41
    That FFDSHOW comes bundled with a FFVFW. Other than that, I have no other codecs installed. But the glitches are still there and when I convert using TMPGEnc Plus, the glitches are carried through onto the MPEG-2. Please help!
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    well they are probably encoded into the avi file --- other than hand removing them frame by frame --- not a lot you can do ...
