Results 1 to 11 of 11
  1. Hi everyone.
    For the past couple of months, I have become extermely busy and have fallen behind in VHS converting. Anyway, I am looking at methods of converting VHS to DVD again, and while looking, came across an article about dual layer DVD burners that can burn up to 8.5GB. Are these drives worth getting or should I stick with the single layer DVD burners?
    Thanks.
    "A mind is like a parachute. It only works when it is open"
    -Martin O'Hera (My Favorite Martian)
  2. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Well...I know there are 2-packs of DVD+R DL's out there now, but at $30, it's far beyond not worth it...$30 will get you 50 4x DVD's now if you look around... (Just got authentic PRODISC for $30, and they work beautifully.
    17GB $30 Dual Layer Little Support
    200gb> $30 DVD+-R Current Standard
    Just wait till the end of the year..will be much better support, more of the bugs worked out, and probably be under $2 a disc.
  3. To be completely honest, the $15 per DL disc is not what's holding me back from a DL burner, it's the uncertainty of compatibility that concerns me.
    I do wedding/special event videos, and there have been times where I've had so much video, I've had to use 4 discs. Being able to get all of the video on 1 or 2 discs would certainly be huge for someone in my situation, but what's the point of the DL discs won't work in my client's dvd player??
  4. I'm just learning all this DVD stuff myself, but as for them not being compatible with standalones that should not be a problem....I mean almost all DVD movies nowadays are DL....its just we are finally able to write them ourselves.
    Come to Ap0calypse!!!!!
    WIN A PRIZE
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The problem comes from the method we use to write to them...we burn them whereas commercially they are pressed. This is a massive difference and this is where the compatibility problems are born.
    If in doubt, Google it.
  6. So the idea should be wait a see how they bear out?
    I was looking at this one:
    http://www.liteonamericas.com/us/DVDRW_832S.htm
    Newegg has it for $99 and it does do 8x where as my old one is only 4x, I don't need to up grade right now but the idea of being able to do dual layers is appealing plus the bump in speed would be nice.
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The price of DL media is still rendering it out of reach for the average home user IMO. I'm going to wait and see what happens regarding compatibility and I'm quite happy to stick to DVD5 @ 8X for another 12-18 months. I guess if you can get the burner at a song now, and you have the need for a DVD burner of some description now, then plan for the future and get one with DL capabilities.
    Bear in mind that I am a staunch - supporter, it also worries/annoys me that all the developments in terms of quicker speeds and DL and things like that are happening to +R first
    I don't want to start a flame war, but it seems that + is ahead of - in terms of development and has been for the last 6-12 months or so as far as I can tell.
  8. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Too late, JERK!
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Too late, JERK!
    Read my avatar
  10. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    I see the children are at play :P
    Be nice now kids!
    I too will be waiting for other's to adopt dual layer burning if nothing else than to wait to see which MEDIA is the best.
    - John "FulciLives" Coleman
  11. I've heard their current "goal" is 90% compatibility. I'm sticking with my PX-708A for the foreseeable future...
