Hi I am trying to choose between the two DVD burners.
But the Pioneer will cost $22 more for an OEM model. The Optorite will cost $67 for retail package.
Pioneer is $89 OEM.
If there is not a big difference between the two I will go with the cheapest.
Should I consider a third option???
I would appreciate your feedback.
Thanks a lot,
skuba
My opinion: Pioneer, never had problems with their burners. I wouldn't be too concerned with OEM VS retail. The retail software included is usually not worth the price. I paid $140US for a Pioneer 104 a year or two ago, and it still works perfectly, albeit slower than my present P106.
Hey man. TULL RULES! Anyway, I have an Optorite drive albeit not that model. Although I have finally gotten my Optorite to work well, I was for a long time unhappy with it. If I could do it all again, I would have maybe spent a bit more and bought the Pioneer or better yet, waited until the Pioneer would be the same price as the Optorite.Originally Posted by aqualung2003
I too fell for Optorite's "retail" package. I advise you not. Their included software is crappy and I got an OLD version of NERO along with other programs that I don't use because they are bad or lite-versions. OEM is fine since you can find NERO pretty cheaply anyway and most other useful programs are free (DVDShrink etc.)
Plus, Pioneer supposedly works better with -R media, something to keep in mind since Optorites reportedly work better with +R. As a -R user myself, this is a bit of a bummer although I can still burn perfectly with quality media.
My vote's for Pioneer OEM definetly. -
I have the Pioneer 107 and find it's probably the best burner that I've ever had.
Not had an Optorite but they have a reputation of being a cheaper brand. -
I would get a LG burner at www.newegg.com very good I also have a Pioneer AO4 also very good one thing I like about LG it support's DVD-RAM
Upgrade Pionner DVR-450H-S/550HS/650HS
By fdchiu in forum DVD & Blu-ray RecordersReplies: 9Last Post: 24th Nov 2012, 11:55 -
rca dvr dvd burner problem
By ziggy919 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 1st May 2009, 20:38 -
DVR DVD Burner
By Nightshiver in forum DVB / IPTVReplies: 1Last Post: 5th Dec 2007, 19:31 -
Pioneer DVR-107D mistakes certain DVD+R/DVD-R discs as "blank CD"
By litmus in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th Sep 2007, 14:38 -
TYG03 burns at 18x in DVR-112D, only 4x in DVR-107D
By mikewillnot in forum MediaReplies: 1Last Post: 15th May 2007, 17:28
