I tried to make a copy of an Audio CD with Nero on a CD-R (for making backup CD ) but that CD is not playing on my VCD player. How can I create a Copy of my Audio CDs on CD-R?
Any freeware suggestions?
do any cd-r audio discs play in your VCD player?
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I cant confirm this as I burned two audio CDs on CD-R and both dont play.
However MP3s/VCDs written on CD-R play on my VCD player. Should I write at lower speed than 8X? -
You need to rip the CD to your HD first. I like Easy CDDA Extractor but Cdex is good and it's freeware. Rip in PCM and then any CD burning program should burn a disk. Nero should be able to make a direct copy,did you use CD Copy mode? Some Cd's have copy protection.
Some devices will not play CDr's. Get a CDr from a friend and try it. If his playes and yours dosen't you can try to fix it. I might add that they should be on the same media, because some burners, and players don't like some media. I doubt it is a cpoy protection problem, because the disk was copied, it plays on the computer". Also you can check your burn with CD Speed.
Mike
?!! Exact Audio Copy vs. dBpoweramp !!?
By flashandpan007 in forum AudioReplies: 12Last Post: 1st Jun 2011, 16:21 -
!!! Exact Audio Copy 99,99% enough? Parameters OK?
By flashandpan007 in forum AudioReplies: 14Last Post: 13th Feb 2011, 09:51 -
megui copy audio how ?
By miss in forum Video ConversionReplies: 2Last Post: 3rd Sep 2009, 10:28 -
why i am not able to copy audio cd contents to HDD?
By sumeshkri in forum AudioReplies: 2Last Post: 22nd Oct 2008, 00:01 -
MPEG2 - Copy audio channel to other
By Francesc001 in forum EditingReplies: 3Last Post: 15th Jul 2007, 22:43
