Hi,
I know that handbrake produces divx files (which i guess may not be playable on one's standalone dvd player (right?). is that why one has to use forty-two dvd mpplus and ffmpegx to convert a dvd to svcd rather than just use handbrake which seems to be a fantastic application otherwise?
Also, once one has a divx file produced via handbrake, I guess one can use divx doctor to convert the file to quicktime format, i.e.convert mpeg-4 to mpeg-2 format, right?
Also, alternatively one could use sizzle and mpeg2works to convert the resulting divx file from handbrake's rip to convert to a dvd-r, right?
sorry for these probably inane questions. would appreciate the edification/instruction.
thank you en avance.
tab
Also, alternatively one could use sizzle and mpeg2works to convert the resulting divx file from handbrake's rip to convert to a dvd-r, right? -
I ran into problems with attempting to compress a video_ts folder to 700 mb today twice. Twice in the last 18 hrs. I ended up with files that were zero kb, i.e. after 4-5 hrs. of handbrake's processing, the end result was an empty set. Last night I had been able to produce a file, (an avi file, all that hanbrake produces), but it had been 1gb in volume. I had forgot to check the target 700 mb space along with the only a single pass having been made. Thus this morning I had 1 gig file that played in VLC. (I have since downloaded Divx Doctor II which I assume allows the avi file produced via handbrake to be Quick Time player playable: am i right ? Once I get another avi file, having trashed the one gotten earlier, i will attempt the quicktime conversion.)
The problem is that even though I have twice tried to end up with a 700 mb avi file, I have ended up with zero kb files instead. The first time when i actually ended up a file I had neither attempted a second pass nor checked the 700 mb target size, to reiterate.
have you or anyone else had this happen in your experience?
Thanks -
Just to add to Liver4ever's helpful answer:
the topic says you want to make a VCD? If that's correct you probably don't want to be using Handbrake at all. Handbrake makes divx files while VCDs are mpeg1.
Also, divxdoctor doesn't encode video. It basically just "fixes" non-playing-audio and puts the contents of your avi container into a QT-friendly mov container. You cannot make mpeg2 files with it.
Live4ever is also spot-on about using mpeg2works and sizzle. Yes, it CAN convert a divx into a DVD/SVCD, but you'd get much better results doing the conversion direct from the exracted DVD instead of from a divx. (Every time you convert video you lose quality, so you just want to do it once if at all possible).
[ASK] Handbrake 0.9.5
By czgirb in forum Video ConversionReplies: 17Last Post: 28th Jan 2012, 16:29 -
Handbrake
By Han Solo1 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2010, 13:14 -
Handbrake
By Bazza-61 in forum Blu-ray RippingReplies: 4Last Post: 19th Oct 2010, 06:16 -
breaking news: 12 dead, 31 wounded in Fort Hood, Texas shooting
By deadrats in forum Off topicReplies: 1Last Post: 5th Nov 2009, 15:19 -
Handbrake question
By stiltman in forum DVD RippingReplies: 1Last Post: 12th Mar 2009, 07:17
