I got a DVD that supports DTS and so does my Amplifier but the problem lies that my DVD has a coaxial output and my amplifier has an optical input.
Ive looked around on the internet and have found some gadgets to convert it from to another but i dont know if it will function correctly.
Any response would b great.
most of the branded amplifiers such as DENON & YAMAHA usually let you reasign the digital inputs on the amp , on my denon i reasigned the optical dvd input for the cd coaxial input , as my preference is coaxial.
i have got a Yamaha one n i also have a coaxial input for my CD player (which i dont use), would u have any idea on how to do it?
if you go to set up on the yamaha amp it should come on the screen with 1 to 15 settings (from memory , i have owned a couple of yams)one of those settings should be for digital in assignment or similar , press enter or move arrow to the right to get into the digital assignment submenu , where it has the dvd input it should be showing optical , use up or down arrow to move it to a coaxial input you are not using , (please bear in mind this is going by memory & that you might have to press slightly different buttons for it to work).
CHEERS MATE!!!!!!!!!!!!
This is much appreciated!!!!!!!!
Saved me £££'s cuz i dont have 2 buy any extra equipment now.
Thanx -
if you get it working can you let me know , as my brother has a RXV 730 & i can double check with him in the morning & post it here.
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
Help -prob playing mkv w/dts&emb subs on Samsung ln40b650t1fxza LCD
By sldiri27 in forum Media Center PC / MediaCentersReplies: 1Last Post: 26th Oct 2009, 02:34 -
Help -Prob playing mkv w/dts&emb subs on Samsung ln40b650t1fxza
By sldiri27 in forum Newbie / General discussionsReplies: 0Last Post: 25th Oct 2009, 23:55 -
Video Amplifier or not
By mysts in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2009, 09:15 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 06:12
